OSPFv3.RxPktAuthFail
Description
This event occurs when authentication fails for a packet received on an interface. Adjacency will go down on the interface. vrid: OSPFv3 instance interface: Interface index
Remedy
There was a mismatch in authentication type or key. Check authentication configuration on interface. If you wish to re-establish adjacency without authentication, then remove authentication configuration from both sides of the link, delete interface from OSPFv3 and add it back.
Severity
Warning
Message Text
%vrid%: Authentication failed for packet received on interface = %interface%.
Message Parameters
Name Type
vrid String
interface String
